| Quote: | Originally posted by WormHole
You're not trying to upgrade, you're trying to downgrade. This is not advisable since it's wise to always use the latest stable version of any
software. Plus I just installed hacks to your site not an hour ago and you're wanting to wipe out my work already. This does not make me very happy
at all. You should have thought about this before having hacks installed. I wouldn't mind so much if you had offered to pay for hacks to be installed
like you did at another site. But when I do it for free and someone wants to immediately wipe out my work that makes me not want to install hacks for
you. Who's to say, and I've seen this many times, that if I install hacks and then you install hacks and mess up and the only way out that you see
is to restore the board? POOF There goes all my work down the drain. And then you'll come back here wanting them all installed again. As I said, I
have seen this type of thing too many times. So bear in mind that doing either of these two things (downgrading or restoring after hacks are
installed) may result in your requesting priviliges revoked. Only upgrading a board is really tolerated since security is more important than hacks.
Noooo, i'm trying to downgrade your work. early i went to request another hack from XMB 1.9.8 Final SP2. I didn't see all this list on there.
BB Code (Blinking Text)
Auto Zodiac Sign v1.0
Display Guests In Who's Online v1.0
Advanced Robot Identification v1.0
Age Display in Posts and Profile v1.0
FlashChat v4.7.12
Awards System v1.1
Latest 10 Posts Marquee v1.0
Minimum Post Characters v1.0
Stats Bar v1.0 -(at the buttom footers)
User Rank Icons image v1.0
Ignore Members v1.0
Stats Calendar v1.1
Bio Center v1.0
State Flag Selection v1.0
Custom Field: Favorite TV Show v1.1
Custom Field: Favorite Movie v1.1
Custom Field: Favorite Artist v1.1
Custom Field: Country v1.1
Country Flag Selection v1.1
But when i click on XMB 1.9.5 Nexus(final). It's has those lists. I was just trying to see if XMB 1.9.8 Final SP2 take those hacks too. That why i
made a post.
